Author Topic: Problems with latest version of Hamachi V2.0  (Read 1491 times)
G8JNJ
« on: November 05, 2009, 04:46:09 AM »
Hi All,
I tried the new version of Hamachi (V2.0) yesterday.
It no longer corectly supports running at startup.
The application is now split into two parts. A service must be up, running and stable, before the application can run correctly. So you can't simply put it in your startup folder and let it run on boot.
This is a major problem for me as I power up my PC's with a PSTN controlled mains switch. So it needs to startup correctly before I can get remote access.
Anyone got any suggestions for a fix ?
Regards,
Martin - G8JNJ
www.g8jnj.webs.com
N2VPC
« Reply #1 on: March 02, 2010, 09:54:44 PM »
Write a script that verifies the service is up before loading the application.
