Author Topic: car fri  (Read 4752 times)
K8ELI
« on: February 10, 2003, 10:42:37 PM »
i got a tuneup on my car last week. and know i hear noise on my mobile, ht, and scanner when in the car or within five feet from the car when i reive the motor up. i have no clue what the problem could be. i checked the plugs and they where rfi filtered. would anybody know what the problem could be?
KA7GKN
« Reply #1 on: February 10, 2003, 11:03:27 PM »
more information please...
1. what make model year is the car?
2. does the noise remain the same when reving the engine?
3.is there noise with the motor off and the ignition on?
4. is the car fuel injected?
5. ford has rfi producing fuel pumps in the gas tank the dealer can fix them
6. many more questions but you need to provide as much information so we arm chair troubleshooters have something to work with
good luck marty
ka7gkn@arrl.net
WA4PTZ
« Reply #2 on: March 03, 2003, 05:47:48 AM »
Since you got a tune-up , did you get the plug
wires replaced as well ? Did you ask for resistor
plugs ?  It could be as simple as a loose or
damaged spark plug wire.
73 - Tim
AC6DN
« Reply #3 on: May 12, 2003, 03:05:45 AM »
Open spk wire.
If u all ready check that every thing is connected.  Then, when they pulled off the plug boot of the sparkplugs they probably broke a wire.
I recommend:
http://www.magnecor.com/magnecor1/main.htm
CN-25 8.8mm wires...
Email them for the proper pn for ur car.
There not inexpensive!, and u have to mail order them.
No substitutions!!!
Bruce
