Author Topic: pulsating rfi problem -any suggestions???  (Read 577 times)
K0YGO
« on: October 09, 2005, 07:06:55 PM »
recently had this problem at my qth
with tv reception using rabbit ears
with all am radio reception
yaesu vx-5r handi talkie on weather band 162.425 mhz
THE PROBLEM
a regular constant pulsating source of rfi - 5 seconds on 1 second off - 5 seconds on 1 second off - 5 seconds on 1 second off continual 24h/7 days
THE TRACK DOWN
using the vx-5r on 162.425mhz started walking the neighborhood - across the street at a vacant home for sale the signal was so strong it desensitized the receiver
DEALING WITH THE REALTOR
called the realtor and the listing agent came right over - explained the problem and demonstrated the problem on my tv, am radios, and the vx-5r
went to the vacant house - nothing obvious was seen after a thorough search - turned off and reset main breaker to home and the problem disappeared - temporarily, it reappeared the next morning at 0720 hours - called realtor again and he came right back - this time turned off circuits individually - living room circuit appears to be the problem - it was left off by the realtor and for the past 48 hours no rfi -
ANY SUGGESTIONS ON THE SOURCE?Huh
nothing is obvious source of rfi - any suggestions will be appreciated
thanks a bunch
Robert W. Barclay, K0YGO
Royalton, IL
K4SAV
« Reply #1 on: October 10, 2005, 09:32:33 AM »
This question had 3 replys yesterday.  I hope you read them quickly because they have been deleted.
N3ZKP
« Reply #2 on: October 10, 2005, 11:34:22 AM »
<<  I hope you read them quickly because they have been deleted. >>
No they haven't. The replies are in another forum where he also posted this question. Smiley
W5RMZ
« Reply #3 on: October 12, 2005, 07:25:45 PM »
CHECK FOR SMOKE ALARMS THEY CAN BE A SOURCE OF RFI
VE3IOS
« Reply #4 on: October 16, 2005, 07:08:58 AM »
Smoke alarms would not be wired through the on off switch to the living room. I would look for older style dimmer switches on the walls particularily the ones with timmers on them, and older style light fixtures. They radiate noise.
N4UE
« Reply #5 on: October 31, 2005, 01:46:32 PM »
Also check for a bad doorbell xformer. This one bit me once!
At least you're lucky enough to isolate the problem to a specific house/circuit!!!
ron
N4UE
