Author Topic: FM Radio Interference  (Read 2625 times)
AB3CX
« on: April 11, 2007, 12:46:24 PM »
My next door neighbor experiences some distortion on his FM radio when I operate on SSB, but not CW. This is at high power output levels only on HF bands 20 meters or shorter. His radio has an internal ferrite antenna and no provisions for an external antenna. It probably has no power transformer. In my own home, on a fairly cheap portable FM radio with a whip antenna, my wife cannot hear any interference at all. His radio is a boom box type unit, plastic case, probably not much shielding. I use a low pass filter. I'm making him a power line RF filter, but if this doesnt work, any suggestions?
WA1RNE
« Reply #1 on: April 12, 2007, 12:38:31 PM »
  The line filter may work, as some FM portables without whip antennas loosely couple the front end to the line cord for use as an antenna.
 If your neighbor is connecting external speakers or line inputs that can be another way for RF to enter the radio. Those cables will need to be decoupled for RF with bypass capacitors and/or ferrite cores.
 ....WA1RNE
K7KBN
« Reply #2 on: April 13, 2007, 04:44:40 AM »
The only internal ferrite rod antennas I've ever seen are for AM radios.  Are you sure his FM receiver uses this kind of antenna?
Pat K7KBN
CWO4 USNR Ret.
