Author Topic: Sprinkler System RFI  (Read 2121 times)
K1FEV
« on: May 15, 2007, 10:58:40 AM »
When I transmit on 20M the sprinklers go on. Any suggestions?
« Reply #1 on: May 15, 2007, 01:04:06 PM »
Change bands, or use 20m only when the lawn needs watering?
K1FEV
« Reply #2 on: May 16, 2007, 08:41:57 AM »
I don't ragchew enough to keep the lawn wet. Good thing it's my sprinklers, all I have to do is unplug the power transformer.
KC9IIZ
« Reply #3 on: May 17, 2007, 06:51:16 AM »
I work for a place that has the auto flush toilets and anytime one of us with a work radio (UHF) transmits from a bathroom ALL the toilets flush.
I really freaks out the users of the toilets.
The manufacture has yet to figure out why. You would think that 2-3 watts would maybe affect one if you were very close to it. But is is all in he room. Some of these rooms have 20 flush units.
K1FEV
« Reply #4 on: May 17, 2007, 06:55:16 AM »
What a crappy deal !
N3OX
« Reply #5 on: May 17, 2007, 11:20:58 AM »
"I don't ragchew enough to keep the lawn wet. Good thing it's my sprinklers, all I have to do is unplug the power transformer. "
Well there's a overcomplicated solution to this problem...
Get a band decoder for your radio, the kind that has relays to automatically switch auxiliary gear as you change bands.
Wire the sprinkler power through a relay that opens when you're on 20m ;-)
Dan
Dan
http://www.n3ox.net
WA1RNE
« Reply #6 on: May 19, 2007, 06:18:56 PM »
 Ferrites on the power cable and wiring to the control valves should take care of it.
 ...WA1RNE
WB6VIC
« Reply #7 on: June 10, 2007, 10:36:21 AM »
I put a switch to disconnect power to the solenoids.  That way the power transformer can stay plugged in and the timer doesn;t lose its programming.  I have to remember to turn it off and on, of course.
