Author Topic: Westell model 6100 internet modem  (Read 2897 times)
AA5WG
« on: May 28, 2009, 07:30:33 AM »
Our Westell internet modem model #6100 is generating tons of RFI on the HF bands.
Our DSL customer service and tech service informed me that they never heard of this problem.  They said they have no cure for the RFI.
The RFI is emitted only when (1) the ethernet output line is attached to box or (2) when the input phone line is attached and/or when (3) the power plug is attached.
I tried adding torids to the above cables with no luck.
Any ideas to cure this RFI/EMI from this modem?
Thank you.
Chuck - AA5WG
KF7CG
« Reply #1 on: May 28, 2009, 07:58:30 AM »
Try to get them to replace the modem. The older models (circa 2004,2005) didn't have that kind of problem. It is their responsibility to provide you with a clean modem when they provide service.
KF7CG
AA5WG
« Reply #2 on: May 30, 2009, 04:08:25 AM »
KF7CG:
They will not replace the modem unless I pay for it.
Chuck - AA5WG
WB4BYQ
« Reply #3 on: June 01, 2009, 07:09:27 AM »
Please try amidon ft-240-77 ferrite cores by winding
about 12-15 turns on the power cord, and the phone line.  also, use a shielded cat 5 cable from the pc to the modem. maybe some snap-on ferrite cores type
31 from dx engineering on the shielded cat 5.  another idea is to put the modem in a aluminum box with with the cores on the outside.  the amidon 77 mix is tuned for the hf frequencies.  also look at the power supply for the modem, try a true transformer type if you can find the correct voltage, if is a switching type it will make hf noise as well.
WB4BYQ
« Reply #4 on: June 01, 2009, 07:26:32 AM »
Please look at this web site.
http://www.olympixcorp.com/rfchoke/comp-install.htm
just type in rfchoke.com and read the articles, and look at the pictures.
this should give you some ideas.
AA5WG
« Reply #5 on: June 02, 2009, 03:40:44 PM »
WB4BYQ:
Yes, these are good ideas.  Thank you.
Chuck - AA5WG
K1CJS
« Reply #6 on: June 07, 2009, 07:04:04 PM »
I believe the modem runs off 12 VDC.  Try eliminating the wall wart it runs off of and use a clean power supply or a 12 volt battery to check it.  A lot of times the power supply is the cause of most RFI problems which are only evident when cables are connected.
