Author Topic: COAX Strain Releif  (Read 436 times)
KB1JIU
« on: February 20, 2003, 09:00:10 AM »
I will be feeding two or three center fed dipoles with coax and PL259 connector terminations.  The coax runs will leave my vertical and free run at an angle to the center of the various dipoles.  These runs will be aprox. 45 to 50' above the ground so I would estimate a suspended length of 50' of coax.  I would like to use LMR400 grade coax.  So now for the question(s)...
QUESTION 1) It would appear to me that the amount of free hanging weight I am asking the PL259 connector (which will attach to the dipole) is alot.  What should I do for strain relief on the PL259?
QUESTION 2) How and with what should I attach the two runs of coax to the vertical?  I will be running the COAx up a patio post, inside of a PVC pipe.  When it emerges into the air, I would like to attach it to something and provide a drip loop.  What should I attach it to to give a flexible strain relief where it emerges?  Is there some kind of springing or bungee type line connector that I can use?
There was some sort of data on this in the April 1987 QST in Hints and Kinks but I do not have that issue.
Thanks for your help.
Art KB1JIU / W1SWL
« Reply #1 on: February 20, 2003, 04:48:38 PM »
I'm not clear on what you're really trying to do, there.
However, LMR-400 cannot self-support for a horizontal span of 50 feet, outdoors, regardless of strain on the connector.  For such an application you need a messenger cable (or strong rope) with the LMR-400 tied to that.  You might want to reconsider the dipole idea, unless the dipole is made of strong copperweld and pulled very taut, it's going to sag a great deal with the weight of 50' of LMR-400 hanging from it.  When the cable gets weighted with rain, snow or ice, or when the wind blows, the cable is going to "pull" on the center of the dipole with the force of 100 lbs or more.
(A dipole tensioned to 25 lbs pull, which is fairly typical for dipole installations, could sag to half its unburdened height with the weight of 50 lbs of LMR-400 hanging from its center.)
I'd re-think this, or at least draft a mechanical stress analysis on paper to predict what's going to happen before you go through the work of an installation that's going to fail.
WB2WIK/6
