Author Topic: ICOM IC706MKIIG CW filters -- help  (Read 2172 times)
N7DKK
« on: September 07, 2003, 06:39:19 PM »
Think I've decided on the IC706MKIIG for an all-around get-started rig.  But I have a question.
I'm a CW OP and it seems like there are 13 filters available for this rig!
13!
It can't hold all 13, can it?
If I just want CW filters, what should I buy?
Your input is greatly appreciated!
-dave-
AD5X
« Reply #1 on: September 12, 2003, 04:29:50 PM »
I tune around with an FL-223 1.9 kHz filter, and then switch in the FL-101 250 hz filter.  Works great.
Phil - AD5X
N7DKK
« Reply #2 on: September 16, 2003, 11:00:43 AM »
Thanks, Phil, that was just the information that I was looking for.  Thanks!
-dave-
VE7BGP
« Reply #3 on: November 20, 2003, 12:27:35 PM »
Hello Dave and all other IC-706 MKIIG users
I use the FL-100 on my 706 G and I am happy with the results. If you just work cw use the correct FL-100 in the menu. If ypu do a lot of PSK and MFSK you can cheat and have the FL-100 help you filter out the crowd by setting the FL-223 instead of the FL-100 you can select narrow in ssb and the FL-100 gives you 500 Hz bandwith. just use your if shift to select your station in the bandpass. I hope that helps.
Gerry
