Author Topic: Using 2 G5RV's cris-crossed > possible?  (Read 2395 times)
KG4GZW
« on: March 16, 2005, 06:03:39 AM »
Currently i have a G5RV running N & S. Im wondering can i also run one E & W.on the same mast.How close can they be with out affecting performance as long as they are not touching each other?
« Reply #1 on: March 16, 2005, 02:01:12 PM »
If they're installed at 90 degree angles, any spacing works -- including touching each other at the feedpoint, and feeding them in parallel.
WB2WIK/6
KG4GZW
« Reply #2 on: March 16, 2005, 03:13:17 PM »
Thanks for info,but unfortunately they wont be flattopped as i have it now.At my soon to be location it will have to be inverted,question is will i be able to use dual G5RV's inverted (cris-crossed N&S/E&W)
W8WZ
« Reply #3 on: June 14, 2005, 12:10:54 AM »
Not sure you would really gain all that much from doing that. The pattern of an inverted V is more omni-directional than a flat top to begin with.
