Author Topic: Buried Coax Recommendations  (Read 1110 times)
KD8BVJ
« on: July 23, 2006, 08:01:42 PM »
I need about 125 feet of coax. I suppose I will bury it directly. Does anyone have any recommendations? Bury-Flex looks good but is there a more affordable alternative? I would hope my installation will last 10+ years.
KD8BVJ
« Reply #1 on: July 23, 2006, 08:31:53 PM »
Also there will be two bends. One ~45 degrees and one 90 degrees around my house. Someday I will use a 1 KW amp but for now it's 100 watts to a Butternut HF-6V.
KB9CRY
« Reply #2 on: July 24, 2006, 06:51:30 AM »
Personally I like the direct burial stuff from CableXperts.
www.cablexperts.com
Phil  KB9CRY
« Reply #3 on: July 24, 2006, 08:23:29 AM »
My recommendation would be don't bury it unless you have to.
KD8BVJ
« Reply #4 on: July 24, 2006, 08:53:06 AM »
Thanks. Cablexperts has a 500 foot minimum. I need 110 feet. I was thinking about Bury-Flex. I will have to bury it. Just to keep it out of the way.
W3LK
« Reply #5 on: July 25, 2006, 07:41:49 AM »
<< Cablexperts has a 500 foot minimum. >>
I think you misread something. I've ordered from them and never ran into this.
Lon - W3LK
Baltimore, Maryland
KD8BVJ
« Reply #6 on: July 25, 2006, 08:59:24 AM »
Thanks Lon. It's not important now. I ordered from Thewireman.com last night.
As it turned out RF Parts online ordering was a hassle also. There order form would not work with my browser. I will give Cablexperts another try next time.
Thewireman E-Mailed me 40 minutes after they opened this morning and said they are shipping my order today!
          Thanks Again
W3LK
« Reply #7 on: July 25, 2006, 09:07:33 AM »
Glad you got what you needed.
Lon - W3LK
Baltimore, Maryland
N3OX
« Reply #8 on: July 25, 2006, 10:37:46 AM »
A run of 2" PVC electrical conduit is cheap, easy to bury and will give you something to pull new runs of coax or rotator/control cables through later.
Just a thought.
Dan
Dan
http://www.n3ox.net
KD8BVJ
« Reply #9 on: July 25, 2006, 11:55:45 AM »
I am tempted to use some sort of conduit. I would need 90 feet. That's with one 45 and one 90 degree turn.
               Thanks
« Reply #10 on: July 25, 2006, 01:08:02 PM »
That's probably about $30 worth of PVC. Be sure to use a "swept" 90 so you don't have any sharp bends to pull through.
KD8BVJ
« Reply #11 on: July 26, 2006, 05:44:53 AM »
What is the best way to pull the conduit or does it go in during the assembly of the conduit?
KD8BVJ
« Reply #12 on: July 26, 2006, 05:45:28 AM »
I mean "pull the coax"
« Reply #13 on: July 26, 2006, 09:45:00 AM »
Coax is unlikely to pull around a 90 degree bend unless the bend has a large radius -- surely larger than a PVC elbow.
Anyway, the conventional way to pull wires through PVC tubing is the same as pulling them through metal conduit:  Apply some grease to the wires and pull them through with a "fish tape."  Cheap tool sold in hardware stores and electrical supply houses.  If the pull is straight and not too long, you don't need the grease.
If I were burying PVC specifically for ham radio use, I'd make it larger than 2" diameter.  Makes pulling easier, and makes adding more cables later a whole lot easier.
WB2WIK/6
WILLY
« Reply #14 on: July 26, 2006, 03:12:57 PM »
 by N3OX on July 25, 2006
"A run of 2" PVC electrical conduit is cheap, easy to bury and will give you something to pull new runs of coax or rotator/control cables through"
What about condensation?
Won't the PVC slowly accumulate water, such that the coax and rotator cables will be soaking in water all the time?
That can't be a good thing.
I remember reading about this somewhere, but can't remember what said next.
Any comments from anyone?
