Author Topic: telescoping mast  (Read 690 times)
9V1VK
« on: August 01, 2006, 07:31:35 AM »
I bought a spiderbeam antenna for permanent use in singapore.  i should have bought a telescoping mast to go with it, because it's otherwise impossible/impractical for me to elevate.
I'd like the mast to allow a rotor, as well.
Spiderbeam sells nice telescoping masts that would allow a rotor on the bottom, however they are damn expensive (300euro for an 11m pole) [plus all the shipping from europe]
http://www.spiderbeam.net/sb/index.php?cat=c12_Aluminium%20Masts.html
anyone know of any feasible alternatives that are less expensive?
K8JDC
« Reply #1 on: August 05, 2006, 11:51:32 AM »
Rohn makes a 44-foot telescopic mast that I have used for my 20m Moxon (with light-duty rotator).  I removed the top-most section as it is pretty small-diameter stuff, but the mast is usable in the 35-foot range if properly guyed.  The cost for the Rohn mast was around $80 USD.  I don't know if you can get one there, but they're fairly decent in my opinion.  In the US, Channelmaster makes a similar mast, but it is smaller in diameter than the Rohn mast.
Hope this helps...
Dave / K8JDC
K3JVB
« Reply #2 on: August 14, 2006, 07:10:37 PM »
...Rohn also make a nice 50 footer too . Again, with the top section removed, it handles my hex beam, and Channel master at 40 feet.
NC2F
« Reply #3 on: September 29, 2006, 04:10:57 AM »
I once used an aluminum extension to ercet a j-pole 45' in the air. It worked great. I secured it against my deck with ropes as a temporatry antenna. I used it for a bit longer than I intended to since I didn't use the ladder for much of anything else. Emphasis on temporary.
