Author Topic: IC-746PRO Backlighting  (Read 820 times)
AB1HF
« on: July 02, 2007, 07:53:00 AM »
I'm looking for my first base station transciever, and an leaning toward the IC-746PRO since I want HF and 2m.  Lots of people seem to love these, but there also seems to be a persistent problem with failure of the display backlighting.  Has ICOM remedied this problem in the new units? Or should I just run it at 100% backlighting as some suggest?
K1RRR
« Reply #1 on: July 02, 2007, 04:52:20 PM »
If you buy a new one or one manufactured in the past several years the problem has been corrected. I love my new one!!!! A great radio value!!!!
KE3WD
« Reply #2 on: July 05, 2007, 10:55:33 AM »
The early 746 backlight problem can be permanently cured by locating the transistor that controls the thing and heatsinking it.
Description here:
http://www.ham.dmz.ro/icom/ic-746-backlight.php
If you don't do that, running at 100% backlight means the pass transistor will be running at the coolest possible temperature and should last as-is.
If you want to dim the screen and have an early model, best to do the mod.
