Author Topic: Antron 99 on 6 meters?  (Read 3376 times)
KF4DVG
« on: November 09, 2001, 01:14:19 PM »
Has anyone tried to use or modify an Antron 99 /  Solarcon 11 meter antenna (without the ground plane kit) to work on 6 meters?
Thanks
Bob KF4DVG
KB9UMT
« Reply #1 on: November 15, 2001, 12:20:59 AM »
Hello:
Yes the A99 will tune and load up for 6 meters.  You will make some contacts if the band is wide open.  Does it radiate and receive well just because you can get it to load up on 6 meters???....NO.  I would suggest that you use a simple wire dipole or J-pole for the six meter band and I think you would have better results.  There are many wire/jpole/delta loop/beam antenna ideas on the web here so search out and I think you would be better off with a seperate antenna for 6 meters and they really take very little room and are cheap to build.  Here is just a couple examples......73 de KB9UMT Don
http://www.users.bigpond.com/lionelc/6meterdi.htm
http://archimedes.galilei.com/raiar/cactus.html
