Author Topic: Yaesu G-1000SDX rotor question  (Read 3041 times)
K0CKH
« on: July 27, 2002, 06:49:10 AM »
I bought a G-1000SDX rotor a couple years ago and am just now putting it up.  It has a 7-pin round connector at the rotor end and uses a 6 wire control cable.  The manual says "pin 6 (the center pin) is not used".
Pin 4 is the center pin, not 6.  Does anyone know which pin in not used?  Is it pin 4, the center pin, or pin 6?
Thanks + 73,  Charlie  K0CKH
K0CKH
« Reply #1 on: July 28, 2002, 08:38:38 AM »
As a follow-up.  I used my ohm meter to see what pins weren't used.  The connector has 7 pins and the rotor only uses 5 of them.  It turns out that pins 1-5 are used and 6 + 7 are not.
73,  Charlie
