Author Topic: SMA Vx5r  (Read 3401 times)
WA2JHS
« on: July 18, 2002, 04:53:23 PM »
Hello,
What is the sma connector on the vx5r, male or female?
Thanks
Bill
KL7IPV
« Reply #1 on: July 19, 2002, 01:24:36 AM »
Mine is female. Hopefully everyone else's is too.
Frank
KL7IPV
KG4RUL
« Reply #2 on: July 19, 2002, 10:05:54 AM »
I understand real estate on some of today's 'mini' ht's is in short supply but, can't designeres come up with a connector that is a little more robust than an SMA?  That center pin is about as fragile as anything I have ever encountered in a connector.  It is great for a situation where you put it together once and forget it.  In the real world, where many connector matings are likely to occur, failure of that pin is only a matter of time.
Dennis - KG4RUL
KL7IPV
« Reply #3 on: July 19, 2002, 05:58:45 PM »
Doesn't someone make a SMA to BNC adapter that you can put on your radio and leave? Then the only change needed is to just untwist the BNC and the SMA connection is left undisturbed. Since I don't undo my SMA much, I don't feel the need to use an adapter.
Frank
KL7IPV
K8ZO
« Reply #4 on: July 19, 2002, 09:49:38 PM »
http://www.eham.net/reviews/detail/2145
KD6JLS
« Reply #5 on: July 26, 2002, 12:50:53 PM »
Yeasu makes an SMA to BNC adapter. I use it. But I have seen some more robust adapters that have rubber grommits which help seal the connection and also support the bigger BNC. I wish I knew where to get them.
K8ZO
« Reply #6 on: July 28, 2002, 12:34:00 PM »
See two messages above for one of the best according to the reviews on here  http://www.eham.net/reviews/detail/2145
Dick  K8ZO
AB0TJ
« Reply #7 on: August 01, 2002, 10:00:52 PM »
Bux.com sells SMA to BNC and SMA to PL-259 connectors for $2 i beleive it is. He has lots of good stuff on his site.
73 and GL,
Alex AB0TJ
K8ZO
« Reply #8 on: August 02, 2002, 05:59:29 PM »
Bux.com got me an internet company??
N6AJR
« Reply #9 on: August 04, 2002, 02:56:51 PM »
Bux com's address is http://www.buxcommco.com/  .  Buck is an alright guy and does a pretty fair job with his business..he has a lot of weird little connectors like a 7 pin mini din for yaesu and such, also has some psk kits and such  check him out...
tom N6AJR
