Author Topic: HELP: gamma match  (Read 2690 times)
DU2YOC
« on: December 27, 2001, 04:42:14 AM »
i'm having a problem with with my yagi antenna because i had a high vswr with the gamma match that i did.what maybe the problem? does someone know how to make a better gamma match or even other types of tuning/matching(that is not too technical) a yagi antenna for 2 meter.tnx
KU4AB
« Reply #1 on: January 02, 2002, 01:58:32 PM »
check out the ARRL antenna book.. look up gamma match
in the back index.. the formluas are listed to figure
the series capacitance.. distance from driven element,,
and length of gamma match.. i used it to make a new
gamma match when converting a Mosley 27mhz beam that
I salvaged into a fine 6 meter beam.. i even used the capacitor off the 27mhz gamma match just shortened and
got a 1.1 swr at 50.125mhz..  good luck   if you cannot
find the  formulas.. answer in this forum.. i'll put
it in another reply.,,.73's phil  ku4ab
N4UE
« Reply #2 on: August 21, 2002, 04:05:49 PM »
Hi, last year I reinstalled my Cushcraft 5 el, 6 Meter antenna. I didn't like the Gamma match because of the slewing of the pattern. Go to the Cushcraft website. Download the PDF for the 617 Boomer. There is a nice illustration of the "T" match. It was easy to duplicate with scrap tubing, etc.
GL
ron
N4UE
