Author Topic: Crank Up Tower ReCabling  (Read 218 times)
KD5FOY
« on: August 21, 2005, 08:52:17 PM »
I've have a us towers tx 455 up for about 5 years and
and am wondering if it makes any sense to recable it
with Phillystran or something similar?
« Reply #1 on: August 22, 2005, 05:33:41 AM »
No. Phillystran is designed to be used for guys. I don't think that the outer covering would do well being pulled over pulley assemblies to raise and lower a crank up tower. If you expose the inner Kevlar to the sun's UV rays it will become brittle and break. I don't know what advantage Phillystran could have in this application anyway.
The steel aircraft cable you have should still be in good shape after only 5 years.
« Reply #2 on: August 22, 2005, 08:44:07 AM »
The TX-455's original cable should last 20 years unless you're using it underwater...
I wouldn't replace it.
KD5FOY
« Reply #3 on: August 22, 2005, 05:35:13 PM »
many thanks for the quick info.  i have no info on
how long steel cable should last.  i'll ask the question
again in 15 years:-)
tnx again
larry
kd5foy
