Author Topic: Possible to remotely locate a 20m beam antenna?  (Read 1270 times)
KC9KEP
« on: September 23, 2009, 08:26:34 AM »
Hello!
I'm not sure how to articulate my question .. but here goes ..
I am considering mounting a 20m Moxon antenna on
my garage in my back yard.
My house is about 80 feet from the garage.
I would need to run coax from the Moxon to my
house where my "shack" is.
I'd assume that my primary challenge would to be minimize
cable losses.
Does this seem at all workable?  Would I just seek the
lowest loss 50 ohm cable such as RG8X or similar?
Thank you for any and all comments :-)
« Reply #1 on: September 23, 2009, 08:40:17 AM »
I'd just use a larger cable such as RG-213.  The losses
should be small enough not to worry about as long as the
SWR isn't excessive.
You can use VK1OD's transmission line loss calculator here:
http://www.vk1od.net/calc/tl/tllc.php
to compare the losses of various cable types and lengths.
100' of RG-213 has less than 1dB of loss, while the same
length of RG-8x has just over 1dB.  Either would work fine.
« Reply #2 on: September 23, 2009, 10:07:31 AM »
80-feet isn't much of a run for 20M. I've got about a total 150-foot run out to the tower and then up.
« Reply #3 on: September 23, 2009, 10:49:42 AM »
My shortest coax run (out of eleven of them) is 165 feet.
No big deal.
I'd also use RG-213/U (not RG8X) for this.
If you have to string the cable between a detached garage and house, one easy way to do that is to install a strong hook into the structure on each end and run a messenger wire stretched taut between those two hooks (use a turnbuckle to tension it), then just hang the coax from that using tie-wraps or similar.
15 minute job.
K9KJM
« Reply #4 on: September 23, 2009, 11:42:49 PM »
80 feet is not very far, Especially at HF frequencies for coax loss.
Belden RG 213 is considered the "Cadillac" of coax for HF use.
But you could use lots of other types, If you bury it, I would be sure to put it inside some type of conduit, Even just a plastic pipe, AND be sure to also lay in a bare copper wire outside the conduit for a ground wire to bond your systems grounds together.
If money is a problem, Check with your local cable TV people for "spool ends" of various types of coax and hardline that will work also, For about free.
