Author Topic: 6 Meter Question  (Read 1194 times)
AJ0HH
« on: May 02, 2004, 01:44:12 PM »
I have an ICOM 706 and am wanting to utilize my R7 as the antenna for 6 meters as it covers that frequency range.  My question is since the 6mtr/hf output on the radio is out of the same connector, can I run a jumper to the 6 meter tuner/swr and then out to the hf tuner and utilize the radio on hf as well as 6 meters, or do I need an hf/6mtr duplexer to go to the 6 meter swr/tuner and hf tuner, then through a switch or other unit back to the radio?
KC8AXJ
« Reply #1 on: May 03, 2004, 01:50:08 AM »
If you have a bypass switch (bypassing the tuning components of the 6 M tuner) in that tuner, you'll be O.K. running HF through it. If not, naturally the 6 meter tuner will have an effect on what you run
through it, that being the HF frequencies.
Steve
AJ0HH
« Reply #2 on: May 03, 2004, 11:43:38 AM »
That's what I thought.  Thanks.
KC8AXJ
« Reply #3 on: May 03, 2004, 01:11:39 PM »
You didn't say what if any tuner you have now. I have this, which has a bypass feature:
http://www.mfjenterprises.com/products.php?prodid=MFJ-906
Or, if you get a MFJ 949E (which I also have)it has a bypass option too, and have one coax going to your 6m tuner and the other (“Coax2”) for other antennas as the 949 has two SO 239’s. If you ever get a ladder/window/long wire feed antenna up, there are separate posts for that as well.
I have heard of folks using the 949 for tuning 6M as well?? Though a post out there and see what the others say.
http://www.mfjenterprises.com/products.php?prodid=MFJ-949E
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=48711&item=3094792199&rd=1
A “D” with rear views
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=48711&item=3094355698&rd=1
You can get a 949 D or E ( E is just newer but NOT much different) on eBay for about $50-$90.
Steve
K7VO
« Reply #4 on: May 07, 2004, 12:18:15 PM »
The MFJ-945E (smaller tuner) does claim to work at HF *AND* 6m.  I don't know about the 949E.  I've never needed a tuner on 6m.  My beam is resonant.
BTW, 6m through a vertical is fine for band openings.  For local/regional (up to 300-400 miles away) you'll suffer 20db polarization loss on SSB/CW/digital.  A small beam or loop will do much, much, much better.
Caity
K7VO/4
