Author Topic: Any One Else Have a Motorola Spectra for 900 MHz  (Read 1269 times)
AJ0HH
« on: May 09, 2004, 11:54:01 AM »
I have a Motorola Spectra which has been converted to 900 MHz Amateur frequencies.  Recently I decided to put the radio back in the mobile and upon power up, the display would not completely light up.  As it is now it flickers.  The transmit light comes on, intermittently if I key the microphone at the right angle (the button snapped the support for it once, but if I hold it right, it will key the radio).  I can receive, but really not sure if it is completely 100 percent on the transmit.  I did some testing locally and it appeared to be working, but it would be nice if I could see the display to know what frequency I was on.
Any ideas on what might be the problem with it?
KØCFI
VA3WXM
« Reply #1 on: May 10, 2004, 11:33:56 AM »
You might also want to post your question and/or read the archives here:
http://batboard.batlabs.com/index.php
They even have a forum specifically about converting Motorola equipment for use on 900 megs ham.
KC7NOA
« Reply #2 on: May 13, 2004, 06:41:26 PM »
I have 3 GTX900 and 2 GTX800 radios ...
similar.. but not the same...
just stating that i have 902Mhz interest ...
