Author Topic: Good source for HT battery inserts?  (Read 1313 times)
AD4HH
« on: February 10, 2004, 12:08:25 AM »
Whats the best source for HT battery pack inserts or rebuild battery packs?
I have an EBP-10N I need to fix. havent had luck in soldering individual cells to replace bad ones in the past.
Charles
KQ6EA
« Reply #1 on: February 10, 2004, 02:58:44 AM »
I've had excellent results buying pre-made packs from The NiCad Lady. They'll even install the inserts if you send them the dead pack. Very good prices, and outstanding service!
KC2MMI
« Reply #2 on: February 16, 2004, 11:02:38 PM »
Charles, if you replace individual cells in a pack you will probably be wasting your money. The new cells won't be charging/discharging the same way that the old ones do, so the old/new cells wind up "fighting" each other and the entire pack will never work as well as simply replacing the whole thing.
Since new cells keep coming out with more power for less price, replacing old cells is even more of a loosing proposition. Most of the old commercial packs are cheap 600-700mAh AA's and you can rpelace them with new 1800-2200mAh cells, tripling your running time for just a few bucks more than the cost of the old cells.
KC0PZE
« Reply #3 on: February 17, 2004, 12:29:00 AM »
Charles,
Give batteriesamerica.com a try. I just ordered an new 2200 mah pack for my Yeasu FT 530 for $28. I was pleased to say the least.
Take care
Ed
WA9SVD
« Reply #4 on: February 21, 2004, 08:30:30 PM »
As stated previously,
                1. www.nicdlady.com
    The NiCD Lady
                has inserts and can rebuild a battery pack.
                2. www.ebatterytech.com
     Battery-Tech, Inc. is another alternative.
                NiCd Lady is in California; Battery-Tech is in New York.
                I've had good luck from both companies.
N2HBX
« Reply #5 on: June 29, 2004, 10:40:42 PM »
Check to see if you have a Batteries Plus store near you...these guys are great!
Larry, N2HBX
