Author Topic: Yaesu VX-5 users: (question)  (Read 320 times)
VE2CZ
« on: August 19, 2004, 01:12:18 PM »
Has anyone out there ever used the VX-5R with an external dc power supply?
Does the E-CD-5B car adapter support the radio on full transmit power?
KG4RUL
« Reply #1 on: August 20, 2004, 09:32:57 AM »
I believe the manual states that it only works on receive when being supplied with power via the charging connector.
Dennis / KG4RUL
VE2CZ
« Reply #2 on: August 20, 2004, 11:40:16 AM »
Hi:
That's kind of why I'm asking, actually. If you are referring the comment on pg 11 of the handbook, I think this relates to using the  NC-72 charger only. I can't handle the 2A needed for full power TX.
On pg 1, it says "when 13.8V DC power is suplied from an externalpower source, power output is five watts on all bands".
I just want to be sure this is legit and others have tried it before I cook the radio....
Chris
KG4RUL
« Reply #3 on: August 21, 2004, 08:43:16 AM »
Very ambiguous at best!
Dennis / KG4RUL
KC1MK
« Reply #4 on: September 06, 2004, 04:27:16 PM »
I have used my VX-5R with external 12VDC (using the Yaesu cigarette-lighter adapter cord) and it works fine, including a full five watts on transmit. The supplied wall-wart charger can't provide sufficient current for transmit, but if you provide external 12VDC with sufficient current capability, it will work fine.
Jeff, KC1MK
