Author Topic: TS-570D & PK-232/PSK  (Read 3482 times)
N9KZN
« on: July 20, 2002, 04:44:53 PM »
Control for the Kenwood TS-570D and PK-232/PSK
This is TNC02's First Demo Release v1.0
For MS-Windows95/98.
TNC02 is Freeware.
Download it from http://home.att.net/~n9kzn/03000.html
-This program should be intuitive and self-explanatory. Hints will display
  when the mouse cursor is placed over the target area or button.
-Customization of the program is achieved by editing pages in the Ini File Setup
 found under the utility tab
-The PK-232 program is activated first
-I use PK-232/PSK radio 2 interface to monitor the local 2m-packet network
-The type ahead buffer will transmit with a double click and radio will automatically
  return to receive after it sends the message
-The Database will display with a double click in the terminal window
-The TS-570D program is found under the Radio Tab
-I use the PK-232/PSK radio 1 interface for the Transceiver
-The S-meter will display active with one mouse click in the main Frequency area
-You will need to make a CQ.wav and SB.wav file to use the "Call CQ" feature
-The TX button function is for tuning-up the transceiver in using FSK mode
-There are example Morse Code Messages.txt for Morse Code operation from the
  transceiver
-You can copy the transceivers memery (0-99)
-The PSK31 programs are found under the SndCdPgm Tab
-The PSK31 program has operational hooks into the AEA/Timewave
  PK-232MBX/PSK TNC and the Kenwood TS-570D HF Transceiver
-The Database will display with a double click in the search entry field
-Double clicking after pasting text in the input buffer will send the message.
Enjoy...
