Author Topic: TS2000 and PSK31  (Read 1180 times)
KG4TIK
« on: September 03, 2002, 01:04:02 PM »
I have connected my laptop to the TS2000 with serial cable - according to the TS2000 manual this is the only connection required.  However, PSK31 software instructions indicate that a connection to the computer sound card and to the transceiver mike is required.
Anyone know what is really required for the TS2000???
K0HZI
« Reply #1 on: September 04, 2002, 08:02:52 PM »
Yes, connections to the sound card are needed to work PSK and other digital modes.  A serial connection can be added to the same com port for CAT control if the software has CAT control feature like MixW: http://www.mixw.net/  Add a resistor pad 10K/1k to the transmit audio and use low power levels to keep from causing interference.  Interfaces can be made or purchased for interconnection to the radio and computer.
One site is: http://www.packetradio.com/psk31.htm
Also read the TS-2000 manual part about external TNC set up to activate the interface.
