Author Topic: Need help setting up packet  (Read 369 times)
N4GX
« on: December 23, 2002, 12:06:36 AM »
I received a new Alinco DR-135TP for Xmas from my brother. The TNC is integrated into the rig. I have followed the skimpy instructions in the manual by connecting an RS-232 cable from my 135TP to my computer. When I boot up the computer it does not see the radio. What am I missing here? What do I need to do next? I am using a US Robotics external modem on the computer that is hooked to serial port com 2. I have set Com 1 at 9600 baud and data length 8 bits, parity none, Flow control to Xon/Xoff as per the manual but how do I set up the EJ-41U (the internal TNC)? Any help will be greatly appreciated. Thanks and 73's
Ed - N4GX
WA9SVD
« Reply #1 on: January 05, 2003, 05:26:19 PM »
For starters, disconnect the ext. modem temporarily and see if you can set up the TNC on COMM Port 2.  That will tell you if it's a COMM Port problem or not.  THEN, if it still doesn't work, look at a serial interface cable problem.  There are all kinds of wiring variations for serial cables, and that could be a problem.  Of course, there COULD be a problem with the radio, but I think that's the least likely scenario.  If you can substitute a different cable, I'd try that first, or use the modem cable from COMM Port 2 to connect to the radio and see if that works.
    Does the radio manual describe the type of serial cable needed, or better yet, give a wiring diagram?
    Lastly, you can ask these questions of the Customer Service Dept. for the radio.  Good luck!
