Pages: Prev 1 [2] 3 4 Next   Go Down
Author Topic: 6M antenna survey  (Read 2763 times)
K3WACKY
« Reply #15 on: July 09, 2009, 01:53:15 PM »
I have used several 6 meter antennas, all with good success at low heights.
Homebrew 2 element quad, 36 inch boom, on an MFJ fiberglass pole, strapped to a 2nd story deck - worked excellent, for portable work, very light weight, just need a philips screwdriver to assemble/breakdown. I'm going to update the design for no tool assembly. Uses a 1/4 wave 75 ohm coax for matching.
I built a 4 element 6m quad that worked excellent out of questionable materials, it came down in a wind storm, but proved I could make an awesome antenna. I'm building another one this year out of better materials and using an antenna analyzer program to optimize it.
I built a 4 element 6m quad for my dad and he loves it.
I made a 6 meter moxon using 3/8 OD inch tubing. It works great and has great band width. Lightweight back up antenna if I need it. Uses a PVC boom, less than 4 feet long.
Currently I use a 4 element yagi with a t-match. I picked it up used from an old timer almost 20 years ago (found in the Ham Radio Yellow Pages!!), but don't know the brand. Works great even at a low height (25 feet)
I used a Ringo AR-6 for a bit at the old house, good for repeaters and hearing Europe.
Never used more than 100 watts - yet
KE4DRN
« Reply #16 on: July 09, 2009, 04:22:03 PM »
hi,
my 6M Moxon is also built from
3/8" aluminum tubing, also works great.
http://www.moxonantennaproject.com/
73 james
K4XZ
« Reply #17 on: July 09, 2009, 05:37:29 PM »
5 element M2 6M5X @ 45' 100 watts.
See you on 6
73 Joe K4XZ
KB9YUR
« Reply #18 on: July 10, 2009, 01:42:32 AM »
90 watts into a KB6KQ.com 6m loop at 30ft.
KE6WNH
« Reply #19 on: July 12, 2009, 07:59:49 AM »
6m Ringo on a mast, 20 feet above ground, no more than 20W. Works for me.
WA9BXB
« Reply #20 on: July 12, 2009, 01:17:08 PM »
5 element Cushcraft at 60 feet.  Run up to 100 watts if needed. Try to use lower power when possible.
N3OX
« Reply #21 on: July 14, 2009, 09:32:58 AM »
"his would be incomplete if the author did spill the beans too....I just built a Moxon (a U type) using 3/4 in
PVC. I won't be doing that again (droopy POS!) "
I've got a Moxon too:
http://www.n3ox.net/projects/sixmoxon
It's a "Home Depot Special," where everything but the coax, connector, and ferrite beads was available there.
It's held up surprisingly well over the last few years.
Recently, I added a five element wire beam constructed with crappie poles much like the popular HF Moxons...
http://www.n3ox.net/files/sixyagi_lg.jpg
Works pretty well, maybe 4-5dB gain over the Moxon.  It'd be 6dB at low angles if it were up a little higher.  It still works noticeably better in most directions.
The two antennas are too close together and so they interact to the tune of a few dB loss when I point one at the other.  Eventually, I will probably take the 6m Moxon down now that I've proven the performance of the 5 element yagi.  Last season I had a hard time comparing because I was using the old Armstrong rotator on the 5 element... hard to peak up
Dan
Dan
http://www.n3ox.net
KF6KDA
« Reply #22 on: July 16, 2009, 01:47:09 AM »
Two 6m Antennas.
GP-15 Multi Band at 25 feet for 6m FM.
M2 6m HO loop at 30 feet using 9913.
Both at 100w.
Used the GP-15 peak of last cycle, had a blast on 6m SSB with it.
KF6KDA
Michael
WB2LCW
« Reply #23 on: July 16, 2009, 01:43:34 PM »
Ok! I have a homebrew squalo at 24 feet(I worked Scotland with it last week)!I ran 100 watts thru 100 ft of 20 year old rg58!
I have a 4 el Hy-Gian beam in the garage being re-habed!This will go to thirty feet on the house chiminey in a few weeks!
I am building a moxon and hope to have it up next weekend!
The 4el Hy-gain is a decent antenna. I have had it for since 1966 and worked many states using 20 watts on AM!
Mike
EI2GLB
« Reply #24 on: July 16, 2009, 06:26:59 PM »
Here i currently have a Eagle 6el with 6m boom up about 65ft.
planning to change to a 7el YU7EF (homebrew) on a 9.5m boom.
in EI we are only allowed 100w.
Intresting to note all the homebrew antennas and the lack of yagis Huh?
hope to hear some of ye over here before the season ends
73's
Trevor
EI2GLB
KB1GMX
« Reply #25 on: July 16, 2009, 07:43:34 PM »
for 6M:
Assorted radios with power ranging from 1W to 200W depending on mood.  All but one HB.
Antennas 4 elements HB at 35ft, also a lawn chair
(the round tube with bends) converted to a square loop
at 18ft.
Mobile, HB QRP SSB, 100W HBamp and KU4AB square loop
mounted in the bed of the Tacoma.
For field work, Par EF6, Copper Square loop, Driver reflector 2 element beam, MFJ 3element beam or the 24ft EDZ wire(50ohm feed).
N6ORB
« Reply #26 on: July 17, 2009, 03:05:39 PM »
I send 100 watts to my Moxon antenna on 13 feet of PVC pipe stuck in a patio umbrella stand in the middle of my back yard. No permanent antennas in my HOA.
N3AWS
« Reply #27 on: July 18, 2009, 06:42:36 PM »
Well, right now I'm stationed in South Korea without a license, but when at the home QTH in Mississippi I use an indoor dipole about 30 feet high.  I run QRP in contests and never more than 100 watts.  I am planning a single element antenna application which I've never seen applied before--if I pull it off and it's successful I'll write it up for eHam.
Jim N3AWS in the Land of the Morning Calm
WB5UDI
« Reply #28 on: July 19, 2009, 06:58:26 AM »
I have a M2 6m HO loop and a 1/4 wave vertical at 35 feet on the roof....so I can switch between them.
My Ranger only runs 25 watts....
I've noticed during the last several openings during June and July, that hams say my 'loop' is a bit louder than the 'vertical'.......I find that interesting. This has been with stations that are West, North and East of me here in Colorado.
73's,
Stan
NG0K
« Reply #29 on: July 22, 2009, 08:10:30 AM »
100w to an alum. dipole up 20ft oriented E/W. Good enough to work sporadic-E's.
73, Doug
73, Doug - NG0K
Pages: Prev 1 [2] 3 4 Next   Go Up
