Author Topic: TS850S + DSP100 + PC Interface. Possible?  (Read 2049 times)
HS1PDY
« on: March 16, 2003, 12:52:55 PM »
Hi,
I made the converter to connect PC and TS850 from IK2BCP's diragram http://www.hamlan.org/tech/kenwood232/knw232.htm  and it works if I disconnect the DSP100.  Now I would like to use both PC and DSP100 at the same time.  Both of them use ACC1 port of TS850.  Any suggestion?
Kanok, HS1PDY
OM7ZZ
« Reply #1 on: June 02, 2003, 10:09:18 AM »
Yes, It's possible. But you must use also RTS, CTS lines and not only RXD and TXD from PC to DSP100. From DSP100 to TS850S use stadard straight DIN6/DIN6 cable. You can find this application at http://www.microham.com/appnotes.html
73 Jozef
HS1PDY
« Reply #2 on: July 01, 2003, 08:22:34 AM »
Yes.  But it looks like I will only work with special design hardware decoder.  Not just the cable, is it?
Regards,
Kanok
OM7ZZ
« Reply #3 on: August 02, 2003, 08:13:37 AM »
No, just the cable and FIF232 convertor or similar RS232 to inverted TTL level convertor.
