Author Topic: RigBlaster Pro ICOM ACC1 Audio + FSK Pinouts Requi  (Read 525 times)
G7EIX
« on: February 16, 2004, 10:07:42 AM »
Hi,
I would like to make my own Audio + FSK ACC1 Cable for my RigBlaster Pro - does anybody have the correct pinouts to make this cable?
Regards
Richard G7EIX
N4ZOU
« Reply #1 on: February 21, 2004, 01:27:14 AM »
I don't know about the Rigblaster side pinouts as I just built my own interface but on the ICOM ACC1 side..
PIN 1 this is the pin that controls FSK Keying.
When PTT is enabled a Mark tone is produced and
when PIN 1 is grounded a Space tone is produced.
PIN 2 this is the ground pin.
PIN 3 this controls PTT, when grounded
the transceiver starts transmitting.
PIN 4 this is the microphone input jack
on the back of the transceiver.
PIN 5 this is the audio output jack.
A 5 pin DIN jack will work just fine in place
of the 8 pin DIN jack if you do not require
squelch, power, or ALC connections which you
should not.
VE2EWQ
« Reply #2 on: April 03, 2004, 06:45:06 PM »
The cable is question has a 9 pin din at one end and 2 mini stereo jacks at the other.  Does anyone have the end 2 end wiring diagram for this cable?
If you do you can forward a copy to gvesnaver@qc.aibn.com
73's
George
VE2EWQ
