Author Topic: USB/Com Port interface?  (Read 1488 times)
« on: December 24, 2009, 09:40:28 AM »
Greetings all:
Once again I am confronted with the problem of finding a USB/Com Port interface cable.  (This is USB cable gizmo that becomes a computer Com Port, usally Com Port 1) This adapter cable facilitates a connection between a computer without a Com Port and a radio or PSK interface unit.
I bought one a couple years ago and was told right off that it "wouldn't work for what I wanted."  He was right and I had to return it. I then put this project on "hold."
I'd like to know what brand, name, model number, etc. of USB interface cables that you are being successfully used these days.  While I am computer literate, I'm no computer geek.
Al - K8AXW
« Reply #1 on: December 24, 2009, 05:43:57 PM »
Anything that uses an FTDI chip set should work fine with all Windows operating systems. Be sure to check their web site for the latest drivers.
AB3BO
« Reply #2 on: December 24, 2009, 06:16:56 PM »
Check out Radio Shack.
Their cable is in my opinion over priced but
it works.
Good Luck.....
KL0S
« Reply #3 on: December 24, 2009, 06:36:30 PM »
Most of the guys (including me) who needed a USB/serial converter have been very pleased with the Keyspan units.  I have two single port and three four port units that work great.
Dino KL0S
W5DWH
« Reply #4 on: December 26, 2009, 01:49:17 PM »
I just bought two from Newegg.com.
Rosewill RCW-617 for $7.99 each. I needed an interface from my computer to the EZ-Rotor control in my Ham IV rotor. They have Windows drivers up to Windows Vista.
AA6YQ
« Reply #5 on: December 26, 2009, 10:36:46 PM »
Here's a list of devices known to work on Windows 7 and Vista:
<http://www.dxlabsuite.com/dxlabwiki/Win7VistaHardware>
      Dave, AA6YQ
KS2G
« Reply #6 on: December 28, 2009, 05:03:04 AM »
I've had good results with the Dynex DX-UBDB9.
There are two versions -- an older one with everything built into the DB9 connector, and a newer one with a circuit-box midway in the cable.
I have both and they work the same.
Many of each listed on eBay for Buy It Now prices as low as $6.00 (plus shipping).
If you prefer retail, the newer one is available (and happens to be on sale) at Best Buy:
http://www.bestbuy.com/site/Dynex&%23174%3B+-+16%22%3B+USB+PDA/Serial+Adapter+Cable/7135664.p?id=1110263657278&skuId=7135664
Good luck!
Mel - KS2G
WA7NCL
« Reply #7 on: December 28, 2009, 08:05:39 AM »
What is it you want it to do?
What operating system / hardware are you wanting to use it with?
There are a number of devices out there, but without knowing why the initial device you tried didn't work and wasn't suitable, we are all just guessing.
« Reply #8 on: December 29, 2009, 08:14:05 AM »
Thank you for this input.  I have this chipset
noted an will use it.
Al
« Reply #9 on: December 29, 2009, 08:15:42 AM »
Thank you.  Will check this out.  I received $50.00
in gift cards for Radio Shack for Christmas!  LOL.
Al
« Reply #10 on: December 29, 2009, 08:18:24 AM »
Mni thanks Dino.  I checked the reviews on the
Keyspan and MOST like it.  I'm noting this in
my book.  Thank you for your help.
Al
« Reply #11 on: December 29, 2009, 08:21:19 AM »
W5DWH:
OK, will research his one.  Thank you for your
input.  'ppreciate your help.
Al
« Reply #12 on: December 29, 2009, 08:22:53 AM »
KS2G:
Rgr on the cable.  What do you use it for?
Al
« Reply #13 on: December 29, 2009, 08:28:42 AM »
WA7NCL:
You're right!  Sorry for the omission.  I am running
Windows XP Home. The speed of the computer is 1.8G and I'm running 2GB of RAM.
At the present time I am using the existing computer
Serial port to my homebrew PSK-31 interface.  While
this is fine, I want to switch over to my laptop,
using the same OS and specs.  The laptop doesn't have a Serial port.  Hence, the problem and question here.
Al
K2PBO
« Reply #14 on: December 29, 2009, 01:44:28 PM »
Beware if you are using Windows 7, 64 bit. I just posted my experience with a $19.95 Ebay USB to CAT cable. I finally got it working.
Steve
