« on: December 24, 2009, 09:40:28 AM » |
Greetings all: Once again I am confronted with the problem of finding a USB/Com Port interface cable. (This is USB cable gizmo that becomes a computer Com Port, usally Com Port 1) This adapter cable facilitates a connection between a computer without a Com Port and a radio or PSK interface unit.
I bought one a couple years ago and was told right off that it "wouldn't work for what I wanted." He was right and I had to return it. I then put this project on "hold."
I'd like to know what brand, name, model number, etc. of USB interface cables that you are being successfully used these days. While I am computer literate, I'm no computer geek.
Al - K8AXW
« Reply #1 on: December 24, 2009, 05:43:57 PM » |
Anything that uses an FTDI chip set should work fine with all Windows operating systems. Be sure to check their web site for the latest drivers.
AB3BO
« Reply #2 on: December 24, 2009, 06:16:56 PM » |
Check out Radio Shack. Their cable is in my opinion over priced but it works.
Good Luck.....
KL0S
« Reply #3 on: December 24, 2009, 06:36:30 PM » |
Most of the guys (including me) who needed a USB/serial converter have been very pleased with the Keyspan units. I have two single port and three four port units that work great.
Dino KL0S
W5DWH
« Reply #4 on: December 26, 2009, 01:49:17 PM » |
I just bought two from Newegg.com.
Rosewill RCW-617 for $7.99 each. I needed an interface from my computer to the EZ-Rotor control in my Ham IV rotor. They have Windows drivers up to Windows Vista.
AA6YQ
« Reply #5 on: December 26, 2009, 10:36:46 PM » |
Here's a list of devices known to work on Windows 7 and Vista:
<http://www.dxlabsuite.com/dxlabwiki/Win7VistaHardware>
Dave, AA6YQ
WA7NCL
« Reply #7 on: December 28, 2009, 08:05:39 AM » |
What is it you want it to do?
What operating system / hardware are you wanting to use it with?
There are a number of devices out there, but without knowing why the initial device you tried didn't work and wasn't suitable, we are all just guessing.
« Reply #8 on: December 29, 2009, 08:14:05 AM » |
Thank you for this input. I have this chipset noted an will use it.
Al
« Reply #9 on: December 29, 2009, 08:15:42 AM » |
Thank you. Will check this out. I received $50.00 in gift cards for Radio Shack for Christmas! LOL.
Al
« Reply #10 on: December 29, 2009, 08:18:24 AM » |
Mni thanks Dino. I checked the reviews on the Keyspan and MOST like it. I'm noting this in my book. Thank you for your help.
Al
« Reply #11 on: December 29, 2009, 08:21:19 AM » |
W5DWH:
OK, will research his one. Thank you for your input. 'ppreciate your help.
Al
« Reply #12 on: December 29, 2009, 08:22:53 AM » |
KS2G: Rgr on the cable. What do you use it for?
Al
« Reply #13 on: December 29, 2009, 08:28:42 AM » |
WA7NCL:
You're right! Sorry for the omission. I am running Windows XP Home. The speed of the computer is 1.8G and I'm running 2GB of RAM.
At the present time I am using the existing computer Serial port to my homebrew PSK-31 interface. While this is fine, I want to switch over to my laptop, using the same OS and specs. The laptop doesn't have a Serial port. Hence, the problem and question here.
Al
K2PBO
« Reply #14 on: December 29, 2009, 01:44:28 PM » |
Beware if you are using Windows 7, 64 bit. I just posted my experience with a $19.95 Ebay USB to CAT cable. I finally got it working.
Steve
