Author Topic: MORSE CAT  (Read 270 times)
KC9DOW
« on: March 14, 2004, 12:29:49 PM »
I am currently in a class learning morse code and we are using the Morse Cat software.  I am having problems so I bought a Bencher BY-1 key and view my code as I key it with the Morse Cat software to see if trying to send will help the learning process.  According to the documentation, I can either "connect your key in parallel to the joystick button #1 or to the parallel port".  Maybe I'm just dense, but I don't know how to identify the joystick button #1 connections on the jack.  Has anyone done this with Morse Cat?
K0RFD
« Reply #1 on: March 17, 2004, 11:15:49 PM »
You won't be tested on how well you SEND code, but on how well you COPY code.
Quit fiddling with your keyer and spend your time listening.
It's what you need to do to pass the test.  Honest.  So get focused.
WA7CC
« Reply #2 on: May 22, 2004, 02:09:08 PM »
On the other hand, if you'd like an answer to your question, go to http://mirrors.xmission.com/hwb/ and look under CONNECTORS then JOYSTICKS and you'll find the information you requested.
