Author Topic: 756 Pro III Keyer  (Read 1476 times)
N3WJ
« on: January 16, 2010, 06:44:48 PM »
I don't know if this is the best forum for this question but figured I would try.  I just picked up a Begali Magnetic Professional (yes, it is a beautiful piece of work).  I want to get some "off the air" time with it to get used to the feel and set up for my tastes.  Does anyone know if there is a way to set the electronic keyer on the Pro III to allow "practice" without transmitting?  Turning the RF power control fully counterclockwise still transmits 5 watts.  I didn't see anything in the manual. Do I just need to run it into a dummy load?
Thanks in advance for any ideas.
TU and 73
Warren
K7PEH
« Reply #1 on: January 16, 2010, 06:59:45 PM »
Set the QSK to off.  QSK is normally set to Full, Semi, or Off.  If it is Off then you can use the keyer and the the side-tone monitor will be heard in the speaker or headphones.
N3WJ
« Reply #2 on: January 17, 2010, 10:20:10 AM »
Thanks, that works perfectly.  To quote Homer Simpson "D'oh!".  I should have figured that one out myself.  I appreciate the quick response.
Warren
