Author Topic: FT857D NO TX RX UHF/VHF  (Read 1547 times)
WM9V
« on: January 26, 2010, 03:53:17 PM »
remove bottom cover
 resolder so239 connector center pin wire to pcb
also solder wire for so239 for hf connector
Symptoms intermittent receive/ transmit on uhf and vhf
no power output vhf/ uhf
the connector center in the so239 will spin in the connector body when a pl259 is rotated while seated in connector
probable cause of broken wire from pcb to rf connector on back panel
PE1HZG
« Reply #1 on: January 29, 2010, 08:07:19 AM »
On my 897/857, the middle pin is actually fixed and does not turn around. That would suggest your plug is broken, and may need replacement; adding a stiffer wire might break the PCB.
Note that the European version has one PL, one N connector; I believe the USA version has 2 PL plugs, perhaps they are different.
Geert Jan
WM9V
« Reply #2 on: March 02, 2010, 01:25:05 PM »
this is the nature of this part
some mfgers had loose middle pins
resoldering it fixed it
i resoldered both panel connectors
the 20 gauge hookup wire they use is too flimsy
comon problem on many radios and cbs
