Author Topic: Programming a Radio  (Read 321 times)
AB1DZ
« on: February 18, 2005, 07:21:05 PM »
Greetings,
I have programmed my Yaesu 7800.  I have some questions.
I have three different 145.190 programmed.  Two into Memory Bank 1, and the third in MB 2.
None of them are DCS, and all have a different CTCSS code.
When I scan memory and 145.190 has activity, how can I know which one to transmit on?
   RG  AB1DZ
W7DJM
« Reply #1 on: February 19, 2005, 09:09:31 AM »
First of all you are going to have to explain to me why you have them programmed this way in the first place.
Did you do this from doing some sort of auto-program-scan?
If so, I'd say the "auto" function is "falsing"  on two improper tones.
Why did you mention DCS, is that what the repeater is supposed to be using?
We need more info here.
I don't know if there are three different receivers/repeaters you are trying to hit with different tones, or whether you just programmed the radio incorrectly.
N6AJR
« Reply #2 on: May 06, 2005, 10:57:02 PM »
the one it stops on is the the one with the correct tone, it will stop there, use alpha letters for identifying which one..
