Author Topic: Using multiple inputs to a cat interface  (Read 261 times)
OBSERVER11
« on: June 06, 2005, 09:31:23 AM »
Icom's CI-V parallels the ports and control is achived via addressing.
If Yaesu uses a hex address for each device, I see no reason why you cannot copy the Icom method.
WB4AXY
« Reply #1 on: June 04, 2005, 09:39:42 AM »
Hello,
I have a Yaesu FT897 with the automatic tuner which requries a connection to the CAT/Data port. I also use the Ham Deluxe Software that uses the CAT/Data port as well. Is there a way to have both devices utillize the same CAT/Data port at the same time? I was thinking of a "Y" adapter. But, I don't know if it would cause damage. Anyone know of a way to do this?
Thanks and 73's
John Roberts,  WB4AXY
