Author Topic: LCD Monitor flickers out!  (Read 266 times)
K1HC
« on: July 16, 2005, 06:02:10 PM »
My Gateway LCD monitor fickers out upon computer start up.  I have been able to revive it sometimes by pressing the "set/source" button multiple times.
I unplugged and cleaned all the cables and connections, opened the computer and re-seated the video card as well.
Any help would be appreciated! Thanks!
Dick, K1HC
K1HC
« Reply #1 on: July 17, 2005, 07:56:28 AM »
Forgot to mention that I swapped in an older CRT monitor, and it works fine.  However, that doesn't mean the video board is OK I suppose because the LCD connect with two cables to the video board while the CRT connects with only one cable.
Dick, K1HC
KE4DRN
« Reply #2 on: July 18, 2005, 05:54:02 PM »
Hi Dick,
The computer will boot up with vga until the o/s
takes over.  That is why it works then fails.
Not all LCD models will work on all of the resolution settings.
Check the settings in the o/s under display,
verify the model lcd is what the o/s has listed.
73 james
