Author Topic: Kenwood IF-232C  (Read 1060 times)
WJ4VA
« on: July 21, 2005, 03:43:04 PM »
I recently purchased one of these interfaces used and can't seem to get it to work, I am using a straight through cable from it to the computer, am I supposed to use a null modem cable?  I don't have any documentation on it.  Any info would be appreciated.
73, Jesse - WJ4VA
KE4DRN
« Reply #1 on: July 21, 2005, 05:21:06 PM »
Hi Jesse,
I've emailed you the manual !
73 james
WA9SVD
« Reply #2 on: July 24, 2005, 11:24:10 PM »
A straight thru cable should work. You need to set your baud rate/parity to match that of the interface, which is, I believe 2400 baud.  The manual will have the gory details.
VE3ZEZ
« Reply #3 on: October 07, 2005, 09:44:22 PM »
Hi
I read your note about using the IF232. I got an LCU-3 with my used 440 rig. I t has the chipset installed. BUT the cable eems to a straight through with 9 pin on computer end  and a STEREO pin connector at the rig end . Have yuo seen this type  and if so whree would it connect on the 440. Theonly opening that matches is the sp out  I am sure this is not where it goes..
I can't find a web  manual(PDF) !!
George Ve3ZEZ
Ottawa
Canada
george.forester@sympatico.ca
