Author Topic: Adjusting Shift - Width - Notch - AGC - ATT - IPO  (Read 5955 times)
AK4FK
« on: March 12, 2010, 09:54:02 AM »
I'm looking for a good web site or book that explains the adjustments of all the filter setttings on the new rigs. For example:
"The sophisticated receiver section utilizes DSP filtering, incorporating features such as Variable Bandwidth, IF Shift, and Passband Contour tuning. Digital Noise Reduction and Digital Auto-Notch Filtering are also provided, along with a manually-tuned IF Notch filter."
Besides trial and error and taking the time to see what effect each setting does is there a good web site or book that sort of explains it all.
I just bought AC6V's book DX101x HF + 6M DXing. I liked it a lot and learned a lot but what I'm looking for is some kind of explanation of each filter and the different settings.
Also maybe some info on setting up for split mode? I understand what it is. Rec and Trx on different VFO's and frequency but how higher or lower do I Trx than Rec. Wow I have a lot to learn. But love it.
Walter
W5ESE
« Reply #1 on: March 12, 2010, 03:49:40 PM »
QST has had a series of excellent articles on just the topics you mention. The articles were written
by Joel Hallas, the Technical Editor. If you are an ARRL member, you can access them through the
online ARRL periodical archive.
Jun 2006 QST   59   Receiver Gain Control (Getting to Know Your Radio)
Article: QST Archive [PDF]
Report a problem with this entry   Hallas, Joel R., W1ZR
Oct 2006 QST   65   Fighting Interference and Noise with Filters
Dec 2006 QST   51   Automatic Level Control
Apr 2005 QST   56   Passband Tuning
Jun 2005 QST   57   Speech Compression
Aug 2005 QST   46   VHF Squelch Modes
Oct 2005 QST   60   RIT-XIT-VFO A/B--What Frequency Am I On Now?
Dec 2005 QST   56   Noise Limiters, Noise Blankers and Digital Signal Processing
Scott W5ESE
WS4E
« Reply #2 on: March 12, 2010, 09:45:47 PM »
I will do you one better.
Here is a search that will find all of Joel's "getting to know your radio" articles from QST.
http://www.arrl.org/members-only/qqnsearch.html?search=1&words=Getting+to+Know+Your+Radio&name=Hallas%2C+Joe&call=&year=&month=&selpub[]=QST
KF6QEX
« Reply #3 on: March 12, 2010, 10:15:43 PM »
This post is for mind readers only.
You know...nahhh...forget it , I am not going to say it....
Smiley
« Reply #4 on: March 13, 2010, 07:10:54 AM »
Fire up the radio and play with it. The PREAMP, IPO, ATTEN depend on the particular radio.
I work CW only. I almost never use IF shift or notching. I do use DSP noise reduction all the time and run IF bandwidth from 100 to 400 Hz.
For CW DX stations often ask for calls 1 or more kHz UP from his TX frequency.
PRE AMP, IPO, and ATTEN? It depends on the radio and the conditions. Some receivers get crunched during contests with the PRE AMP ON. Some (Elecraft K3) do not. When in doubt turn OFF the pre amp and kick in some attenuation.
« Reply #5 on: March 13, 2010, 07:44:11 AM »
Read all you can and then experiment with your own radio.
AK4FK
« Reply #6 on: March 14, 2010, 07:51:24 AM »
W5ESE & WS4E,
Thanks for those suggestions/links. It sounds like that's just what I'm looking for. I just picked up a FT-950 & would like to use it's full potential.  I realized last night I can always do a menu reset so I started adjusting and was able to get rid of a lot of static noise while bringing in both sides of the conversation.  Once again thanks for those links.
Walter | KI4UCJ
