Author Topic: Writing your own CAT software.  (Read 1598 times)
KB4ZQ
« on: March 30, 2006, 04:30:09 PM »
Is there anyone out there that has written your own CAT software.
I'm interested in writing control software for the Yaesu FT-920 HF rig.  I can send commands to the radio with no problem but haven't been able to display information FROM the radio to the computer.
I use MS Visual Basic 6.0 and MS Visual Basic Express 2005 which is free from Microsoft.
I'm not a professional programmer and am retired so this is something fun for me do!
Bruce
KB4ZQ
KE4DRN
« Reply #1 on: March 30, 2006, 04:39:10 PM »
hi bruce,
take a look at this link, it may provide
you with a fix (the sw below is no cost)
http://www.g4hfq.co.uk/ftbcathelp/ftbcathelp.htm
73 james
KB4ZQ
« Reply #2 on: March 30, 2006, 05:28:52 PM »
Thanks for the input.  Doesn't look like the site you mentioned sends the source code (which is the actual computer code used to generate the program itself.)  I need the actual code itself so I can add it to the program I have already written.  Then I'll be able to display the frequency and other outputs for the FT-920 on the computer screen.
Thanks for you input.  I do appreaciate it!
Bruce
KB4ZQ
KE4DRN
« Reply #3 on: March 30, 2006, 07:19:22 PM »
hi bruce,
ok I understand, looks like your half way there,
page 88 in the manual has the formats for the
download command and the data that is sent.
73 james
AA6YQ
« Reply #4 on: April 01, 2006, 01:24:17 AM »
I am the author of Commander, which supports all PC-controllable HF Yaesu transceivers including the FT-920.
Are you using the MSCOMM control for access to a serial port, or another mechanism?
When you send the FT-920 a command directing it to return data, do you see incoming characters?
       Dave, AA6YQ
WA6ODQ
« Reply #5 on: April 26, 2006, 02:30:04 PM »
If you are using MSCOMM, it can be tricky.
Use hyperterminal to be sure you can send/receive data.
Once that is verified, look at your code.  I use the method of receiving one character of a time with InputLen set to one, and RThreshold to 1.
Also look at handshaking, I wasn't able to receive data until my handshaking was set correctly.
Can you post your code for MSComm_OnComm subroutine?
