Author Topic: VX-2 Commander  (Read 1799 times)
KD3RH
« on: January 08, 2007, 03:42:51 AM »
OK, so I'm not the brightest light in the harbor.  Can anyone tell me what I've missed... I write (apparently effectively) to my VX-2, using the KC8UNJ Commander and the radio's then "locked" in memory-only mode -- VFO no more.  Thanks and 73's to the group.
-don
KE7HLR
« Reply #1 on: January 11, 2007, 04:08:24 PM »
See page 43 in your VX-2R manual:
"To place the radio in Memory Only mode, turn the
radio off. Now press and hold in the [V/M] key while
turning the radio on. To return to normal operation,
repeat the above power-on procedure."
I don't think there's anything in VX-2 Commander to set this option, but you might have accidently pressed this key instead of [F/W] when turning your radio on to do the programming...
Anyway, turning on the radio while pressing the [V/M] key should get you back on your feet.
73 de Dan, KE7HLR
