Author Topic: Using Yeasu wires II  (Read 451 times)
XY3LON4
« on: April 07, 2007, 09:57:46 PM »
I own the FT2800M and it has wires build in. The users manual is kind of brief in it's explaination on how to use it. The way it is explained, it is kind of like echolink. The radio has no jack to connect it to my computer and the Yaesu web site isn't any help at all. Can anyone help me on using WIRES II and what the benifits are?
XY3LON4
« Reply #1 on: April 09, 2007, 12:50:05 PM »
Someone has to know about this.
KG4RUL
« Reply #2 on: April 10, 2007, 10:08:06 AM »
Try the Yahoo group on WIRES II: http://tech.groups.yahoo.com/group/wires_voip_general/
Dennis KG4RUL
K1RFD
« Reply #3 on: May 04, 2007, 10:43:44 AM »
The WiRES-II package comes with a cable with a multi-pin connector at one end, and stripped and tinned leads on the other.
You'll need to customize this cable by adding appropriate connectors for your rig.  I believe WiRES requires that you connect incoming and outgoing audio, plus PTT control and carrier detect.  Carrier detect is usually available on a back-panel accessory connector (or "packet" connector).  If there is no such connector on your rig, you'll have to dig in and find a COS line internally.
K1RFD
« Reply #4 on: May 04, 2007, 10:46:04 AM »
Incidentally, I believe that radios like the FT2800M have a "WiRES" feature that allows them to be used in conjunction with WiRES nodes.  It does not mean that the radio can be used *as* a WiRES node, without the addution of the WiRES package itself, which is what I was referring to above.
K6LCS
« Reply #5 on: May 29, 2007, 10:11:36 AM »
There's 200+ WIRES-II users at...
http://groups.yahoo.com/group/WIRES-II/
Clint Bradford, K6LCS
http://www.work-sat.com
