Author Topic: Audio in from Computer on icom ic-7000  (Read 1715 times)
GALAXY0088
« on: August 21, 2007, 08:42:05 AM »
I am trying to run audio in from my computer to my icom ic-7000.  How would i go about doing this?  I have the adaptor that takes the 8 pin modular to the 8 pin round connector.  Now i just need to know which pins to hook the audio into.  If i am using vox to transmit all i would need is the audio input correct?  Any help would be appreciated. Thank You
Joel
KB3OZC
W0FM
« Reply #1 on: August 21, 2007, 09:15:44 AM »
Hi Joel,
Try this site for a ton of connector/radio specific wiring diagrams:
http://www.packetradio.com/
Good luck.
Terry, WØFM
W0FM
« Reply #2 on: August 21, 2007, 09:20:46 AM »
I just realized that you could spend all day looking for the best page on that site:
http://www.commparts.com/MICndex.html
I drilled down a bit further for you.  Hope this helps.
Terry, WØFM
N8UZE
« Reply #3 on: August 22, 2007, 07:29:25 AM »
If you are feeding audio from your computer to the radio, you probably need an attenuator network between your computer and radio.  Look for diagrams for PSK31 (and other digital modes) for connecting to your computer.
