Author Topic: Kenwood TH-F6A programming software - can't print  (Read 2450 times)
N6EG
« on: May 02, 2007, 02:23:23 PM »
I've got an HP laptop running the latest version of Windows 2000.  I downloaded and installed the Kenwood programming software for my TH-F6A.  I have the Kenwood PG-4Y cable attached to the serial port on the laptop (no USB converter cable).
The software runs fine.  I was able to connect with the radio and can read the radio memory data and save it to a file on the laptop.  I'd like to print out the data in my memory.  When I click on Print, I get an error message box with a red X and the following error text.
Huh?? 'Mcp_f6f7.exe' Huh?? 0048CC09 Huh?? 7C00003C HuhHuhHuh??
Can anyone help me figure out what's going on and why I can't print?
Thanks.
N6EG
« Reply #1 on: May 02, 2007, 03:37:25 PM »
O.K., I finally got it to print.  I went into device manager and changed the port to LPT2.  So it prints out just fine but now what's printed is just a bunch of gibberish.  Does anyone have any suggestions?
BTW, the printer is not hooked up directly to the laptop but is a network printer (I'm at work).
Thanks.
KE4DRN
« Reply #2 on: May 02, 2007, 04:17:29 PM »
hi,
did you add a new printer on LPT2 or just
change the port number on network printer ?
73 james
N6EG
« Reply #3 on: May 02, 2007, 07:49:22 PM »
I just changed the port number.  Do I need to add a printer?
N6EG
« Reply #4 on: May 03, 2007, 11:49:07 AM »
What's odd is that the Menu A and Menu B information prints out fine, it's just the Memory channels that come out gibberish.
W7AIT
« Reply #5 on: May 14, 2007, 06:26:20 PM »
I just use the SW to program, never to print.
KB9XN
« Reply #6 on: October 27, 2007, 05:00:16 PM »
If you are using WinBlooz you will have to configure it as a TCP/IP  Network Printer and it will print just fine and dandy after installing the right printer drivers.
Happy QSL label printing
Howard
