Author Topic: Acquiring good ground bonding  (Read 1130 times)
N4NDX
« on: May 30, 2010, 05:40:02 PM »
I have my vertical antenna grounded next to an 8 ft rod and is about 20 away from the house to the left. At the opposite side of the house is the main panel connected to an 8ft rod with a #6 solid copper wire. All of this is at the main level of the house. My future station will be at a 3 sided open basement with a crawl space underneath and about 10ft away from the sub panel and of course connected to the main panel. What do you guys recommend to acquire a good ground bond with this scenario.
"Is the coax cable consider part of the bonding"?
David/n4ndx
