Author Topic: Amp Supply AT-1200 Band Switch  (Read 2358 times)
WB4PPW
« on: May 31, 2010, 04:37:24 AM »
I need a Antenna switch for my AT-1200 any one know of a source or what might work as a replacement??
Thanks for any input.
Jess WB4PPW
« Last Edit: May 31, 2010, 09:21:27 AM by Jesse Knight » Logged
AH6RR
« Reply #1 on: May 31, 2010, 10:31:41 AM »
How many positions is the swtich? Is it a single layer or double? Henry Radio has some very good Band swtiches for amps that are single or double layers that could work for you they are very well built and rated for high power.
Good Luck
Roland AH6RR
W8JI
« Reply #2 on: May 31, 2010, 01:49:42 PM »
Jess WB4PPW
The switch used in the Ameritron ATR15 tuner should be a close replacement. You might have to alter shaft length.
WB4PPW
« Reply #3 on: June 01, 2010, 04:56:50 AM »
Thanks for info. the switch has 5 positions and single layer.  I'll check on the ATR-15 switch.  We have a hamfest this week end perhaps I'll find something there.
 Jess
