Author Topic: interface  (Read 1328 times)
K0BLR
« on: December 22, 2007, 05:31:55 PM »
Good Evening everyone,
 Quick question does anyone know how to make an interface to do cw and other stuff? I run a TS-2000 and I have cat figured out I just need an interface now for cw. I have no keyer.
Ben, K0BLR
N8UZE
« Reply #1 on: December 22, 2007, 05:52:25 PM »
The TS-2000 has a keyer built in.  However, what I think you are asking for is the interface to have the computer key the radio.  You can get an inexpensive interface from the N3FJP web site.  These interfaces go from a serial port on your computer to the jack on the radio for a straight key NOT the jack for the built in keyer.  The built in keyer is for use with paddles.
VK2ACM
« Reply #2 on: December 24, 2007, 03:37:08 PM »
Hi Ben,
You can make your own interface if you want, Please check out our groups blog on the page you will see the schematic of the interface I built in a DB9 shell....Good Luck....Clint vk2acm
W5RKL
« Reply #3 on: December 25, 2007, 01:32:11 PM »
BLR
Yes they can be built rather easily. Depends on what
options you want. Quite a number of hams build their
own to suit there needs. If you're not into building
there are quite a number of commerically available
interfaces for most radios, even vintage gear. It
all depends on what you want.
I built my own for my FT-857D and it works great for
CAT and any digital mode except CW. I didn't include
the CW keying opto isolator but that's soon to change.
Merry Christmas and 73's
Mike
W5RKL
AA6YQ
« Reply #4 on: December 27, 2007, 02:11:05 AM »
If you have CAT working, you can direct your TS-2000 to transmit CW using the KY CAT command; no additional interface is needed.
       Dave, AA6YQ
