Author Topic: Can't access forums with FF or IE  (Read 3662 times)
KI5LP
« on: July 01, 2010, 06:47:03 PM »
OK, this is weird...for some reason, I'm not able to access posting privileges in the forums here on either FF 3.5.7 or IE8.  I've poured through the FAQs, cleared caches, cookies, temp files, etc.  and no luck.
Strangely enough, Google Chrome works without a hitch.
Any insights?  My e-mails to the various support links here have so far gone unanswered...
« Reply #1 on: July 02, 2010, 04:35:36 AM »
What kind of computer?  PC or Mac?  What operating system are you using?  W 7, Vista, XP--or are you running an older system?  What version of IE?  or FF?
You leave out too many specifics to really make any sort of guess--never mind a correct guess.  You've got to give more info that just the bare bones you've given so far!
N2MG
Administrator
« Reply #2 on: July 02, 2010, 05:18:41 AM »
Strangely enough, Google Chrome works without a hitch.  Any insights?
Sounds like a cookie problem.
1. Go to eham.net and log in
2. Log out immediately
3. Log back in
4. Check the forums to see if  you are still logged in (hopefully!)
To whom have you been writing? I dont' recall your callsign at the moment.
Mike N2MG
KI5LP
« Reply #3 on: July 02, 2010, 08:26:41 AM »
3. Log back in
That did the trick.  I had tried clearing the cookies/history/temp files earlier per the FAQ, but that didn't work.  Cool!
Maybe you should add this trick to the "Other log in problems..." section of the FAQ.
Thanks...
