Author Topic: Using Skype for guys that Can't copy net  (Read 3455 times)
W0IH
« on: July 01, 2010, 09:15:27 PM »
I was wondering if anyone has gone through this.
We have a regular schedule with a bunch of guy for a round table (nothing formal) but depending on band conditions, some of the guys can't copy.
Is there an easy way to get them in the loop using the PC and Skype?
  My first thought is to just put a mic in front of the speaker (to broadcast into Skype) and let them listen in.
  But is there a better way?
Mike
  W0IH
LU2DFM
« Reply #1 on: July 02, 2010, 05:41:19 AM »
Yes, make the round table directly over the 'net, because that would eliminate the problematic part, that is, the *radio* part.
KF6HCD
« Reply #2 on: July 10, 2010, 04:43:35 PM »
Mike
  W0IH
AFAIK, Skype has no provisions for the need you are describing.
Look at EchoLink... Conferences are allowed on EchoLink. You would have to facilitate that by buying the hardware and integrating it into your station, but the hardware is not very expensive.
On their end, they would merely log in and operate. You are the sysop.
All info here: http://echolink.org/
Hope this helps.
KF6HCD
« Reply #3 on: July 10, 2010, 07:29:16 PM »
Michael is only trying to utilize different "channels" of communication, and is asking for input.
Do you have a helpful reply?
LU2DFM
« Reply #4 on: July 19, 2010, 10:56:35 AM »
I'm a little tired of nets or roundtables or whatever you call them these days operating semi-duplex over the air (semi-duplex on radio: the other party is NOT really hearing anything in the radio).  It's not that I was very attracted to nets anyway.
I really can't understand the point of "completing" the net by other media... This is about _radio_, not _communication_ isn't it? Because if the point is communication, then IRC or video conference over TCP/IP is way more reliable, cheaper and easier.
And Skype has a conference mode, as most other phone services ;-)
73 de Fer
N5XTR
« Reply #5 on: July 22, 2010, 08:58:06 AM »
Get the other guys on skype and test the audio feed and internet connections.  If everything seems to work, then run with it.  It will make the net more enjoyable for those having difficulty receiving.
Joel ~ N5XTR
W5LZ
« Reply #6 on: July 23, 2010, 01:05:33 PM »
I have to agree with LU2DFM.  Those who can't hear would do well to maybe up-grade their antennas, or whatever else would make the required difference to be able to hear the net.  An alternative would be for the net to adapt to those who can't hear it, not too likely, right?  Or maybe those who can't hear should find another net?  'Skype', 'hype', and 'tripe' have more in common than rhyming.
Paul
