Author Topic: icom 751A What antenna tuner  (Read 4803 times)
SQ9OKY
« on: July 17, 2010, 10:28:34 PM »
Hi, how to buy icom antenna tuner 751A, manual, Kenwood AT-230, Daiwa 419? or automated Icom AT-160? Huh
KN7F
« Reply #1 on: July 20, 2010, 02:25:07 PM »
Look for a used Icom AT-100, 150 to 300 USD or the AT-500, 300 to 500 USD.
SQ9OKY
« Reply #2 on: July 23, 2010, 05:50:39 AM »
ok, thank you
AB8AL
« Reply #3 on: September 17, 2010, 01:48:17 PM »
Check out the LDG tuners.  they will work find and you can get a new one for under $300 US.
NR4C
« Reply #4 on: October 29, 2010, 07:37:47 AM »
Check out a used AH-2.  Nice tuner, different interface from AH-4 but similar.  Will une a 'long wire" or hook up coax to HOT terminal and ground.  Use a balun and ladder-line to a dipole or extended "ZEPP".  Great combination.
...bc
VE7BGP
« Reply #5 on: November 03, 2010, 04:58:37 PM »
Hello
I use a MFJ-993 IntelliTuner with my IC-751A and other radios in my shack including a Fun oldie SB-101 Heathkit and it works fine for me. If you are trying to tune a random wire antenna an AH-2 tuner mounted outside near the antenna will cut down your losses. With any antenna tuner you have the convenience of operating everywhere but your Coax losses goes up and efficiency goes goes down. Use a multiband designed antenna with a tuner G5RV or ARRL Loop Skywire and keep that Coax run short. I use the ARRL Loop Skywire antenna with my MFJ-993. I hope that helps.
Gerry VE7BGP
