Author Topic: Computer Controlled Switches or Relays  (Read 6899 times)
KB9WIS
« on: August 04, 2010, 12:30:21 PM »
I need a way to connect and disconnect equipment remotely.  Basically switch them on and off is all I need.  I have a computer that I can control remotely, so was thinking some type of switch or relay that can be operated by a computer would be the answer..  The problem is, I am unsure where to find such a device..  Any ideas?
« Reply #1 on: August 04, 2010, 01:01:13 PM »
They make IP enabled power switches. You plug the switch into a network, assign it an IP address and connect to it with a web browser. The browser application lets you turn the various recepticals on/off remotely.
KB9WIS
« Reply #2 on: August 05, 2010, 01:24:31 PM »
Thanks, that solves many headaches..  Another thing is that I would like to be able to open and close contacts for only a half a second or so (like simulated pulse/push button switching). so I'm thinking a remote relay of some sorts may work for this?  This is basically to close the up and down frequency controls (through the mic input) so I can qsy remotely on a transceiver that doesn't interface with a computer directly.
Any ideas on how to fullfill this purpose...
K0IZ
« Reply #3 on: August 07, 2010, 01:15:54 PM »
Do a google on n8lp, his website has his LP Remote board.  I use one to control all sorts of things.
